Darrel's Kitfox - SS7
Date:  11-3-2018
Number of Hours:  4.00
Manual Reference:  Contour rib profil
Brief Description:  Contoured rib profile and more work on tip
Sanded out the "hump" set up by the leading edge of the main ribs using the template that came in the kit.
Began filling in the low spots on the wing (i.e., gap between fuel tank and spar and leading edge and spar) with Super Fill.
While waiting for the first mix to set up, worked a bit more on fitting the wing tip on the right wing.
The hump
The hump
After sanding
After sanding
Super FIll in action
