Darrel's Kitfox - SS7
Date:  10-10-2018
Number of Hours:  1.50
Manual Reference:  Fuel tank install
Brief Description:  Continued installation of fuel tanks
Set up and ran leak check on the right fuel tank.
Rough fit the left and right fuel tanks with fittings into the wing bay and marked number one rib for cut out clearances. The final cutting although performed on the 11th is shown here due to the 3 picture limit. The right tank is shown here as it needed a bit of the cap strip removed to facilitate a desire to be able to remove and re-install the pick up without major effort should that ever be necessary.
Laid out the aluminum panels that mount behind the fuel gages.
