Brief Description: Finish install of forward strut attach right wing
Finished drilling the repositioned holes and did final epoxy prep. Found "flakes" in the epoxy and talked to the factory. Apparently they are crystalized components of the compound and will recombine if heated to about 120F.
Installed the strut attach fitting on the front spar of the right wing.
