Darrel's Kitfox - SS7
Date:  9-9-2018
Number of Hours:  3.00
Manual Reference:  Wing jigging
Brief Description:  Re-did the wing set up
Set the dihedral, wing sweep, wing twist and perpendicularity.
It was pretty straightforward, just follow the instructions. Conversations with other builders gave me a hint that made the jog a tad easier (repeatable) - tie the wing tips to something solid; the tape suggestion in the manual allows just enough movement to drive one crazy.
Then, after getting finishing this task, I, for some unknown reason, moved the number one rib into position and discovered that it should have been in its proper position the entire time in order to ensure the root end of the spars were in their proper position. Of course, in complete adherence to Murphy's Law, this was discovered after (only) the top holes were drilled in the forward spars.
