Darrel's Kitfox - SS7
DEW2
Large baffle
Fabricated parts for the large baffle
Located the raw material for 2 reinforcing plates and 2 hangars used on the large engine baffle and fabricated them.
Cut from raw stock what I believe will be pieces of foam rubber that are used to seal the radiators to the baffles.
Drilled the mounting features on the jury strut brackets.
Also, passivated two hangars used in the engine ring.
DEW2 Home
2340
Basic Kit
93
Fabric cover
82
293
Final assembly
501
Inspection
Kitfox Avionics
Kitfox tooling
Kitfox Undercarriage
Kitfox wings
Lighting
88
Paint System
87
335
Tooling
Tooling
