Darrel's Kitfox - SS7
Date:  8-17-2018
Number of Hours:  2.80
Manual Reference:  Large baffle
Brief Description:  Fabricated parts for the large baffle
Located the raw material for 2 reinforcing plates and 2 hangars used on the large engine baffle and fabricated them.
Cut from raw stock what I believe will be pieces of foam rubber that are used to seal the radiators to the baffles.
Drilled the mounting features on the jury strut brackets.
Also, passivated two hangars used in the engine ring.
