Drilled all specified pass thru holes. Riveted top to bottom sections Match drilled and reamed the fifth mounting hole Located and drilled the pedal mounting bolt access holes in the bottom panel
Note: this was my first experience using a Rotobroach hole saw - this is something you don't want to leave home without. Don't know how the settlers came across the country without one.
