Darrel's Kitfox - SS7
Date:  7-2-2018
Number of Hours:  3.50
Manual Reference:  Window
Brief Description:  Finished co-pilot's window and prepped for H/T
Finished the co-pilot's window and prepped for installing the ribs in the H/T and elevator.
1. For the window: same as pilot's window (see previous entry)
2. Laid out rib placement on the work bench.
3. Mounted the elevator to the H/T.
4. Blocked the assembly to the work table.
5. Fitted the two middle ribs and align drilled the bearing access holes.
