Darrel's Kitfox - SS7
Date:  6-1-2018
Number of Hours:  6.10
Manual Reference:  Rudder pedals
Brief Description:  Final install of rudder pedals
The replacement bolts came in and I spent the day installing the rudder pedals. Took longer than anticipated (doesn't it always?) because I took the time to:
1. Remove more friction from the assembly
2. Determine the proper hardware stack-up; required because I had added fender washers under the floorboards to "level" the rudder assembly
3. Add non-slip tape to the rudder pedals
4. Replace the kit supplied screws that mounted the assembly to the floor with bolts
5. Replace the internal bolts with drilled bolts because I feel they will or could be subject to
rotation.
Pedals are in.
Pedals are in.
Replacement bolt detail
