Darrel's Kitfox - SS7
Date:  5-24-2018
Number of Hours:  2.50
Manual Reference:  Vertical Stab
Brief Description:  Installed ribs in VS
Spend over 3 unaccounted hours sanding off most of the polyurethane - it appears I brushed it on just after raising a lot of dust in the workshop and between the air conditioner and dehumidifier they kept it up in the air until it could settle on the fresh top coat. Something really weird did happen though - of the five panels that constitute the flooring, 4 sanded nicely and were no problem. The fifth one - well, not so much. The poly was gummy and I ended up scraping off most with a razor blade and denatured alcohol. Most interesting - all panels had undergone exactly the same processes during the finishing process but only one exhibited this issue. Strange
The 2.5 hours here represent finishing the fitting of the stabilizer ribs, clamping them in place and then putting on just enough epoxy to hold them in place without the clamps - in preparation for making the application of the finishing epoxy easier (clamps out of the way).
Set up and curing
Set up and curing
Done!
Done!
