Darrel's Kitfox - SS7
Date:  5-13-2018
Number of Hours:  5.20
Manual Reference:  Pedal assembly
Brief Description:  Prepared pedal assembly components
Performed the required modifications to the standard pedal pulley mounting control horns IAW the adjustable option.
Fabricated the cable restraining straps.
The above work took a little longer than normal due to solving an interference issue between one of the rudder cable pulleys and its mounting horn (misaligned mounting holes).
Finished rudder pedal components
