Darrel's Kitfox - SS7
Date:  4-29-2018
Number of Hours:  5.50
Brief Description:  Continued work on flight control installation
Finished fitting control sticks to stick pivots (sanded off excess powder coat).
Prepared recesses for pivot bearings (used small brass brush in Dremel to remove powder coat).
Installed 4 socket head cap screws after chasing threaded bushings
Assembled the control stick pivot connect tube and set length between rod ends.
Test assembled connector tube to pivot sticks to determine best washer stack up.
Mounted and finish drilled and reamed control sticks to pivot sticks.
Reamed mounting holes in fuselage frame.
