Drilled holes in the exhayst pipes for mounting the EGT probes. Mounted the EGT probes in cyl 1,2,3. Routed the thermocouple wires for cyl 1,2,3 through the firewall and trimmed to length. The cyl head temp wires need type K thermocouple wires spliced in for most of the length since the input to the Dynon data acquisition unit uses type J wires and the CHT probes are type K. The splice will be made about 12" away from the Dynon unit.
