Removed the dynamo 20A fuselink and replaced it with a fuseholder and 20A fuse. This will make it easier to change the fuse if needed. Labeled the fuse. Secured the loose wires fo rthe voltage regulator and the overpoltage protect circuit.
Voltage regulator, OV protect relay, filter capacitor, dynamo fuse, connection to the 12 V supply.
