Connecting the wires from the Dynon EMS-220 to inputs for the elevator trim, flap position sensors, and the fuel level sensors. All wires identified with labels under clear shrink tubing. Reviewed connections for the fuel flow, oil temp, oil pressure, and fuel pressure sensors. Connected all the EMS-220 ground wires to the airframe common ground point. Connected the position sensors pots to +5 volts and ground as required.
