Ran three wires for the coil, Critical bus, and Endurance bus, from the area of the battery to the front to where the other end of the wires will terminate at the coil connector, and the fuse panel. Wires are run under the floor. Put grommets for the wires in the floor near the battery and in front of the passenger seat near where the main power wires are located. These wires are run inside a clear urethane tube for added protection. Secured wires with cable ties. Fabricated fuse links and a terminal to connect to the +12v input connector on the battery solenoid. The other ends of the fuse links need to be crimped to the three wires. The coil wire is 16 AWG and the two bus wires are 14 AWG.
