Fabricated the cable from the control stick switch cable to the Velleman 2633 relay card. Tested the trim system for elevator trim. It works! Put grommets in the plastic box that will house the relay card. Threaded the control cable through the grommets. Drew schematic diagram of the wiring from control stick to the relay card and trim motors.
