Installed the Dynon ADAHRS OAT sensor. Cut a 40mm diameter hole in the left fuselage side about 100mm below the horizontal stabilizer. Made a 65mm dia. round cover for the hole. Drilled four 1/8" holes to mount the cover to the fuselage side. Drilled a 3/8" hole in the center of the cover and mounted the OAT sensor in the hole. Routed the OAT wires along the route of the elevator trim cable to the center of the fuselage near the mounting location for the ADAHRS.
