Worked on electrical system design. Design for achieving maximum reliability for the fuel pumps and electronic ignition. Created an "always on" buss for the critical fuel pumps and ignition and carb heat circuits, and "endurance buss" for the avionics. The endurance buss can be switched on/off even with dynamo failure. The main buss is switched on through a battery contactor and carries the non-essential heavier loads. I incorporated an over voltage cutoff of the dynamo in case the voltage regulator fails and puts over 16 volts on the system. The OV module is from B&C Electric. Also, the dynamo can be switched off if necessary for some reason. Made a preliminary drawing of this system up to and including the busses
