Installed the nuts on the wing spar bolts. Did not set torque on the nuts. Left the torque wrench at home.
Measured leak down compression on the engine. Cylinders 1,3, 2, 4, 6 were at 73 - 74 lbs, but cyl 5 was 65 lbs. Some leakage noted from the crankcase breather pipe. Test pressure was 80 lbs.
