Louies Web Site
Date:  11-30-2012
Number of Hours:  1.20
Brief Description:  Wiring, spar bolts
Installed wire connectors on both the fuselage and wing ends of the wires to the aileron trim servo.
Fitted washers and nuts to the lower wing spar bolts on the left side. Checked for correct bolt lengths with the nuts and washers on. Bolt length is correct with a short section of the bolt shank showing beyond the center spar. The exposed bolt shank is covered by one washer under the nut.
