Louies Web Site
Date:  11-26-2012
Number of Hours:  3.30
Brief Description:  Fuel line, wiring
Installed AN-6 fittings on the end of a SS braid covered fuel line cut to the correct length to fit between the right wing tank outlet and the fuel line inlet fitting on the right side of the fuselage. Installed grommets where the AN-6 line passed through wing ribs and the side of the fuselage.
Installed push on connectors on each end of the wires leading from the fuselage to the right wing. Connected the wires and pushed them into the space between the fuselage and the wing rib.
Flared the left side fuel inlet line and installed the bushing and nut.
