Applied range markings to the airspeed and oil pressure analog instruments.
Tested the oil sump heater.
Installed fittings on the ends of AN-6 braided fuel line hoses which will connect the fuel tanks to the solid AN-6 aluminum line in the cockpit to the fuel tank selector.
Cut the AN-6 aluminum lines to correct length for attaching the braided SS lines. Installed a AN-6 nut and flared the line on the right side. The left side will be flared and nut installed when I receive nuts ordered from Summit Racing.
