Louies Web Site
Date:  11-12-2012
Number of Hours:  5.00
Brief Description:  Prop pitch & other
Set prop pitch to increase static RPM. I thought the pitch was set for 8.5 degrees, but measuring with a digital level showed it was at 10 degrees. Set the pitch back to 8 degrees. Torqued teh prop bolts to 35 lb ft as the Warp Drive instructions specified. Left the spinner off until I test run it again to check static RPM.
Leveled the Dynon ADAHRS unit so the ball was centered on the PFD display.
