Set up airplane level on top longeron and set up scales. Measured from datum point to the wheel axles. Weighed main gear and tailwheel. Weights adjusted to include weight and moment of wings. Weight includes all interior pieces, seats, side panels, floor panels, wheel pants, wing fairings. Weight does not include any fluids such as fuel or oil.
Weight Arm Moment Left wheel 415 lbs +12mm 4980 Right wheel 408 lbs +10mm 4896 Tailwheel 60 lbs +410mm 246000 ====== ======== ======= Total 883 lbs +289.8mm 255876
Deviation from plans added: Roll bar 5 lbs Raised fuselage top 3 lbs Enlarged rudder 1 lb Instrument panel access panel 1 lb ====== Total 10 lbs
