Trimmed the left bottom fairing. Sanded both bottom fairings and the right top fairing. Added spot layup for fiberglass tape and small pieces of CF cloth to reinforce weak areas. Put a layer of epoxy thinned 1:1 with acetone over part of one of the bottom fairings to fill the deeper sanding scratches. If this works, I'll use the same thinned epoxy to coat the other fairing pieces. It will require more sanding before the final clear coat.
