Riveted the top cover to the top flange of the instrument panel. Re-installed the canopy and bolted it on permanently. Installed the rubber seal around the front edge of the canopy. Covered the top panel from the access opening back to the rear edge of the glare shield with blue vinyl same as the seat trim. Used brushed on contact cement for the adhesive. Put a rubber trim piece on the rear edge of the glare shield.
