Brief Description: Fuel system heat shield cooling
Located a place on the heat shield top to put the cool air inlet. Cut a 1" hole in the heat shield top for the SCAT tube interface. Riveted the tube flange to the heat shield top over teh hole. Mounted the heat shield to the firewall. Attached the 1" scat tube to the plenum on one end and the heat shield on the other end.
