Louies Web Site
Date:  10-1-2012
Number of Hours:  4.50
Brief Description:  Fuel system heat shield
Found that the fuel system heat sheild could not be put in place through the motor mount after all the engine controls have been installed. The heat shield needed to be cut in two with a method to hold the two pieces together when installed. Cut the heat shield in two horizontally. Made a slip joint so that the top piece can be slid into place and held in alignment when the two pieces are screwed in place. Applied aluminum insulating material over the outside of the aluminum heat shield. The heat insulating material is thin aluminum over thin fiberglass cloth. It is self adhesive on the back side.
