Louies Web Site
Date:  9-19-2012
Number of Hours:  3.00
Brief Description:  Lower cowling
Trimmed cured foam from the cowling. Shaped it with a Sure Form file. The shape and smoothness was not acceptable. I applied dry wall patching material to the surface and built it up to approximate the finished shape I want. I worked it down with a Sure Form file. There are still some low spots that need filled with another layer or two. The dry wall patching plaster is vrey easy to work with.
Cowl bottom foam covered with dry wall patch and preliminary smoothing.
