Finished both forward interior side panels. Decided to not use the floor panel I made yesterday. Began fabrication of filler sections to elevate the floor ahead of and behind the landing gear box. I'm using 1" thick foam sheet covered on one side with 3 layers of glass cloth and epoxy resin to elevate the lower fuselage bottom and cover the exposed wires. Added 1/2" thick foam sound absorption/dampening material under the side panels.
