Trimmed the FG cloth and worked down the epoxy/chopped glass filler added yesterday so it matched the outside surfaces of both cowlings. This will make the backing for a 'jog' at the front joint of the upper and lower cowling and will help locate them. Added epoxy/microballon filler to smooth the transition of the lower cowling to the upper cowling. Put one layer of 6 oz FG cloth and epoxy over the filler to protect it and blend it into the base cowling surface.
Left side inlet and material added for strengthening joint with the top cowl.
