Worked on top cowling. Added epoxy and chopped fiberglass mix under the front left top cowl where it overlaps the bottom cowl. The top cowl overlapped the bottom cowl by about 1/4". The gap needed to be filled. Cleaned up the inlet opening on the outside to make the fit better and smoother.
