Removed the plastic form used to make the female form layup from the fuselage. Removed the adhesive from the carpet tape used to fasten the plastic and foam sheet to the fuselage. The adhesive is very difficult to remove. Used acetone, lacquer thinner, and paint remover to get the adhesive off.
