Louies Web Site
Date:  7-5-2011
Number of Hours:  3.00
Brief Description:  Wiring and pitot & static lines
Put a sheath over the run of pitot, static lines and Dynon ADAHRS cable where they are routed on the right side of the cockpit area under the top longeron. Further secured the cable and lines on the right side behind the cockpit with plastic ties.
Made up a 3 conductor cable to connect the flap position sensor behind the flap actuator forward to the Dynon unit. Tested fit of wires and pitot, AOA lines at the top of the cockpit area under the top longeron.
Sheath over right side cables
Right side cable run forward
