Fabricated aluminum fuel line between the gascolator outlet and the first fuel pump. The line had to compensate for a 10mm difference between the firewall mounting surface, the gascolator output and the fuel pump input. The line also needed a 90 deg bend. Mounted both fuel pumps. Pumps connected together with AN fittings. Pumps mounted to the firewall with #10 machine screws. Nut plates installed on the back side of the firewall for the mounting screws. Tested the fuel pumps.
Located the 0.935" mounting hole for the panel mount USB connector for the USB cable to the Dynon Skyview. Made the hole in the instrument panel below the location for the Skyview.
