Attached vinyl covering to the left console side panel using 3M spray Super Trim Adhesive type 8090. Punched holes in the vinyl for the attachment screws. Installed the side panel. Attached the fuel lines to the fuel selector valve.
Surveyed the location for the fuel line from the fuel selector and the location for the gascolator. Temporarily mounted the motor mount to be sure there will be no interference between the gascolator, fuel pumps, and the motor mount. Need to have the gascolator be located high enough so it doesn't hang low and be subject to damage in an off field landing. The gascolator should be the lowest point in the fuel system. The gascolator should be located for easy access to the fuel drain on the bowl. Found a location that satisfies these conditions. Mocked up a layout for the fuel pumps and determined the AN fittings needed. Ordered the fittings from Summit racing (Earls brand).
