Louies Web Site
Date:  6-3-2011
Number of Hours:  3.00
Brief Description:  Instrument panel
Made CF layup to cover the sub panel below the main instrument panel that contains the fuel seloctor, fuel pump, ignition, start switches, and cable controls for park brake, cabin heat, carb heat, and mixture. Removed the sub panel and drilled the holes for the switches, and cable controls.
When the CF layup cured, it had wrinkles where the plastic sheet over the metal form wrinkled when the epoxy covered it.
Made another CF layup directly over the metal form using spray on mold release.
