Fastened the fuse block panel to the bottom of the instrument panel. Used #6 sheet metal screws and Sheet metal nut clips. Epoxied the nut clips to the instrument panel bottom to keep them in place and from shifting. Marked the back side of the CF overlay panel and marked where the overlay cut outs need to be for mounting the instruments and glove box. Cut the openings in the panel with a Dremel tool circular saw blade. Cut two more holes in the instrument panel for an oil pressure gauge and a J&S Electronics knock sensor indicator and O2 sensor mixture indicator. Made two bushings for the throttle rods from 1" dia nylon round stock. Made the bushings 1/4" thick. Riveted the bushings to the backside of the instrument panel.
