Trimmed mounting flange on glove box to correctly fit the glove box centered over the glove box door opening. Layed out location for glove box mounting screws. Positioned the glove box on the instrument panel and drilled mounting screw holes. Installed nut clips on the glove box flange over the mounting screw holes. Test mounted the glove box to the instrument panel. Test fit the backup altimeter and air speed indicator. Trimmed the glove box mounting flange for clearance.
Rough sanded the high spots on the epoxy coated CF instrument panel overlay.
