Louies Web Site
Date:  5-21-2011
Brief Description:  Instrument Panel
Cleaned the CF instrument panel overlay with lacquer thinner because the clear coat I applied yesterday didn't go on smoothly. Put on 4 more light coats of clear coat lacquer. Finished the foam plug for the glove box form. Made a sub panel for the three fuse blocks from 0.016" aluminum sheet. Turned down 15mm of the edges for stiffening. Tested the fit for the fuse block sub panel on the instrument panel bottom.
