Brief Description: Gear leg rear fairing, forward top skin
Attached the left brake line to the rear of the gear leg using three spots of Permatex Ultra Black. When that was cured, trimmed and attached the rear gear leg fairing to the gear leg. Used Permatex Ultra Black on the edges of the gear fairing as an adhesive. Clamped in place while curing.
Marked out the access opening on the forward top skin 6-C-1-4. This access opening will permit access to the rear of the instrument panel. Cut out the access panel from the forward top skin using a scroll saw with fine tooth thin blade. Chris held the top skin while cutting.
