Sanded more on the right side brake cover to smooth the epoxy layup and lighten the cover. Removed the right wheel fairing. Went to The Dalles and bought some sanding filler. Applied the filler to the cover and set it aside to cure. Connected the brake line to the right brake caliper. Attached the brake line to the rear of the right gear leg with Permatex Ultra Black adhesive.
