Routed brakes lines out through the side of the fuselage behind the gear legs. Used generous sized rubber grommets where the lines pass through the fuselage sides and the console side panels. Put two Adel clamps on each line at the rear edge of the gear channel. Glued a short section of rubber channel material on the top edge of the longeron that extends out behind the gear channel. Put a 0.025" doubler on the underside of sub panel 6-K-2-2. It would flex quite a lot when operating the park brake control. Now it is very stiff. I used flush rivets to attach the doubler. The sub panel can be covered with finish material such as vinyl and have a smooth surface.
