Louies Web Site
Date:  3-2-2011
Number of Hours:  5.00
Brief Description:  Seat, Fuel lines, console
Went to The Dalles and picked up the remaining seat and side panel items from Steve's Upholstery. Sanded engine top cover and applied another couple coats of clear coat. Formed both fuel lines so they fit nicely from the fuel selector to the fuselage side openings where the fuel lines come in. Fabricated clamp supports to support the fuel lines as they pass in front of the spar. Drilled holes in front spar angle supports and riveted the clamp supports on. Made cutouts in the console side panels for clearance of the fuel lines. Cleaned up drill chips from the fuselage floor. Tried the passenger seat spacer and the seat cushion. Looks like it will work out ok. Need to have Chris sit in it and try it out.
