Finished drilling rivet holes for Instrument panel support bracket 6-K-6-2 to fasten it to the firewall. Made console side panels 6-K-6-3 because the ones sent with the kit wouldn't fit and the drawings were wrong. Kit was for a dual stick system and I have a single stick. Started on the L angle supports for mounting the side panel. Drilled holes to mount the panels to the center console sub panel. Began working out how the fuel selector will mount and routing of fuel lines through the console side panels. Decided that 45 deg AN-6 fittings at the selector inlets should work best.
Sanded the engine top cover and gave it several more coats of clear.
