Brief Description: Engine top cover, brakes, Inst. panel
Sanded and clear coated the engine top cover. It will need more sanding and clear coat. Worked on the brake system shutoff valve. installed 1/8" pipe adapters to 1/4" tube. Figured out the placement and mounting method. Worked on instrument panel switch, control, and instrument layout. Updated Solidworks drawing to show possible locations. Printed the drawing and marked locations on the instrument panel to see how it would work out.
