Trimmed engine top cover layup. Set it up in the oven for heat treating. Completed the heat treating process over a period og 7 hours. Cut and layed up two layers of CF cloth on a flat surface covered with a sheet of aluminum. Used System 3 epoxy. This layup will be for the instrument panel cover. The panel aluminum is 0.025 aluminum and needs reinforcemnt to be stiffer.
