Louies Web Site
Date:  2-16-2011
Number of Hours:  3.00
Brief Description:  Lift handle
Began design and fabrication of a lift handle for the fuselage slightly in front of the horizontal stabilizer on the left side. Cut out the parts from 0.100" aluminum sheet and 3/8" dia x 0.065" wall thickness aluminum tube. Bent the tube to shape and trimmed. Bent the aluminum sheet, located rivet holes and drilled holes.
