Trimmed passenger seat to narrow the width near the top about 1/4" on each side. Laminated 4 pieces of 1" thick styrofoam for use as a spacer on the passenger seat back so people with short legs could reach the rudder pedals. Took both seat foam assemblies to the upolsterer in The Dalles to check if they could be covered properly. The upholster shop was closed. Attempted to add urethane pourable foam to one edge of the 4" thick spacer so I could make it conform to the shape of the seat. However, one part of the urethane foam had hardened in the container and couldn't be used.
